It would be nice to have a better integration with garmin edge systems, it works but only basic, you can’t put ruuvi as an independent data field. You can read the information in a separate window, valid for Edge 1040.
Hello @Florin_David ,
Thanks for your feedback. Are you referring to an existing third party integration?
Maybe this is related to @zmullett Garmin widget?
Yes, is related to @zmullett Garmin widget
Yes, the @zmullett Garmin widget, the application does not work as it should from the point of view of displaying it as a data screen
If my understanding of Garmin’s User Experience Guidelines and Toybox.BluetoothLowEnergy is correct, it should be possible (for someone with the time to try it
It could borrow from the Widget’s implementation @ GitHub - zmullett/connectiq-ruuvitag: A Garmin Connect IQ watch widget that displays RuuviTag sensor data.
