Just letting you all know, Ubeac is an easy to use tool to inspect HTTP requests and can be used with Ruuvi Station.
“Log, inspect and debug HTTP requests and webhooks in a human-friendly way. Quickly test the connectivity of your devices or application in real-time, so you can get back to working on your use-case. No Sign Up Configure Your Device and Monitor Data Instantly”
Yes, it works. Thank you Lauri for tip.
But be patient. It took me quite a long time (maybe 10 minutes) to get the first message through.
When using Firefox, I could not Export the data, but with Opera browser Export worked OK.
I am not familiar in programming, so I just wonder if I can somehow hook to the collected data directly, or is this just a development tool to check whether Ruuvi sends data correctly?
