I have a problem…I have tried installing Ruuviberry OS and Ruuvicollector OS (not at the same time) and the login pass doesn’t work. This havppened for BOTH versions.
Does anyone here know the correct default login info??
We have not maintained the image in last 4 years, I would recommend installing the components from scratch on top of fresh Rasbian. The blog post of process is at Setting up Raspberry Pi as a Ruuvi Gateway - Ruuvi
You could try “pi/ruuviberry” as the login, but I can’t recall if the password was changed. Rasbian default is “pi/raspberry”
