I got my Gateway yesterday and started setting it up this eve. Have to say, there are too many issues which makes me too mad to describe them in discrete way so I’m just listing them.
Finding a WiFi or LAN MAC address is (quite) impossible prior to setting the gateway up (which may need some tuning of MAC authentication at routers). Actually WiFi MAC seems to be in QR code in the bottom of the gateway but MACs should be clear visible some where.
Won’t negotiate 1GB when wired. Multiple, working fine with other devices, wires tested.
With WiFi, reports a wrong DHCP server - gateway - instead of the real DHCP server
There’s no possibility to define a static network settings when using WiFi
Disconnects WiFi connection into RuuviGatewayXXXX AP every now and then
xxx.xxx.xxx.xxx/auth.html (where it asks if English or Finnish shall be used) is missing a button to enter you language selection and to go forward.
The product and packaging looks professional and finalized enough for me but the software inside is a bit dissappointment.
Edited:
The WiFi DHCP address was supposingly a mistake, perhaps it really happend to be a duplicate to an already existing device or someting (issue removed by now)
There are several ruuvitags around visible for mobile app but MQTT reports repeatedly “status” “offline”, why?
I’m sorry about the issues and thank you for the feedback.
The MAC in QR code is Bluetooth MAC. All MAC addresses can be found in the gateway hotspot at 10.10.0.1/info.json, but the WiFi and Ethernet MAC are not currently on any sticker. I opened an issue about this at Sign in · Feedback has migrated to Ruuvi Forum, we consider the feedback from community when prioritizing new features
The Ethernet IC on Ruuvi Gateway supports only 100 MBit / s and 10 Mbit / s speeds, which is more than enough for JSON data being sent out.
