Hello there,
here is my solution for the cat activity monitor. To lower the energy consumption the code checks every 5 seconds for activity and logs if the cat moved in the last 10 minutes. The “live” 24h movement is broadcasted. To obtain all data call the getData() function. I got some inspiration from the acceleration logger solution from js.
var movement = [];
var movementLog = [];
var lastInterval = 0;
var lastLog = 0;
var activeAt = 1.1; //g value at which the cat is active
function onInit() {
lastLogInterval = Math.floor(getTime());
Ruuvitag.setAccelOn(true);
checkAccel();
function checkAccel() {
var xyz = Ruuvitag.getAccelData();
var g = Math.sqrt(xyz.x * xyz.x + xyz.y * xyz.y + xyz.z * xyz.z);
g = g / 1000;
var interval = Math.floor(getTime() / 600) % 144; //10 minute intervals
if (interval != lastInterval) {
calculateMovement(true);
if(movement.length >= 144) {
movement.shift();
movement.push(0);
lastInterval = interval;
if (g > movement[movement.length - 1]) {
movement.pop();
movement.push(g);
setTimeout(checkAccel, 5000); //every 5 seconds to lower energy consumption
function calculateMovement(publish) {
var active = 0;
for(i = 0; i < movement.length; i++) {
if(movement[i] >= activeAt) {
active += 1;
var percentage = active / movement.length;
if(!isNaN(percentage)) {
if(publish) {
NRF.setAdvertising(require("ble_eddystone").get(Math.round(percentage*100) + "%_CATNAP"), {interval:1000});
checkLog(percentage);
return percentage;
else {
return 0;
function calculateTotalMovement() {
var totalMovement = 0;
for(i = 0; i < movementLog.length; i++) {
totalMovement += movementLog[i];
totalMovement = totalMovement / movementLog.length;
return totalMovement;
function checkLog(percentage) {
if((lastLog + 86400) < getTime()) { // 24h (= 86400 seconds) logs
lastLog = Math.floor(getTime());
movementLog.push(percentage);
function getData() {
console.log("Last 24 hours: " + Math.round(calculateMovement(false)*100) + "%");
if(movementLog.length < 1) {
console.log("Last 24h period: Not enough Data");
console.log("Total Movement: Not enough Data");
else {
console.log("Last 24h period: " + Math.round(movementLog[movementLog.length - 1]*100) + "%");
console.log("Total Movement: " + Math.round(calculateTotalMovement()*100) + "%");
Best regards,
Lenny
Seem’s that it would less data intense to see how many hours your cat is NOT sleeping!
Depends on the cat I guess
Cool! Any plans to add Eddystone advertisements to make it easier to check the readings?
Check this line, it’s already broadcasting using Eddystone.
Ah, that’s true! Missed that line. Contact sales@ruuvi.com to get your reward shipped
Hii, where did you run this code btw ?
With Espruino
