Looks to be a Celsius to Fahrenheit conversion related bug.
When I navigated to “Sensor Settings → Offset Correction → Temperature” screen, the “Original measured value” is reported as 63.58 °F. I tapped the “Calibrate” button, then entered an expected temperature value of 64.1. The corrected value is then reported as 147.31 °F, which is clearly bogus. Seems like the code that processes the entered value thinks the units of the value that I entered are in Celcius, even though I set the “Temperature Unit” in the app’s settings to “Fahrenheit”.
