@tts Hi, Let me start with answering your last question first. Not in general, BTKit is build around RuuviTag and if you are planning to get RuuviTag data on your iOS app its highly recommended to use BTKit.
Now, I am assuming you have the basic idea of SwiftUI app. BTKit works just well on SwiftUI too, it is framework independent.
What you would need is to create a class and implement the BTKit. Here’s a simple example, and you may change it to your need.
import SwiftUI
import BTKit
final class ViewModel: ObservableObject {
private let foreground: BTForeground!
private var scanToken: ObservationToken?
private var ruuviTagObserveToken: ObservationToken?
init(
self.foreground = foreground
/// Start observing all available tag advertisements
private func startScanning() {
scanToken?.invalidate()
scanToken = nil
scanToken = foreground.scan(self) { [weak self] (observer, device) in
if let ruuviTag = device.ruuvi?.tag {
// Do something with advertisements
/// Stop scanning
private func stopScanning() {
/// Start observing a particular tag advertisements
private func startObserving() {
ruuviTagObserveToken?.invalidate()
ruuviTagObserveToken = nil
ruuviTagObserveToken = foreground.observe(self,
uuid: ruuviTag.uuid,
options: [.callbackQueue(.untouch)]) {
// Do something with advertisements data
