Hello I recently purchased a Ruuvi tag pro to monitor my dogs crate while off grid/ without access to wifi while travelling. How do I add the widget to my android phone? Thanks
You can configure a widget by long pressing “Ruuvi Station” launcher in your phone start screen
Thank you for your reply.
When I do that it says " you can use ruuvi widgets if your sensors are in range of a ruuvi gateway or if someone has shared with you a ruuvi sensor"
I thought I could use my phone as a gateway? I don’t know how to configure it so the widget works without internet.
Hello Sahsha,
A Ruuvi Gateway router is required in order to use widgets since it relies on data that is fetched from Ruuvi Cloud.
