hi, I am following your blog post to get familiarise myself. I observed mismatch in current consumption
My setup
Ruuvi development kit
Power profile kit II
I cloned the project and compiled the code 3.1.1-Alpha. When I measured the current, I observed about 20uA current is drawn by the downloaded code. In the blog post it was mentioned 4uA. for me, I am getting 5 times higher than what is mentioned. To check if I am doing any mistake in compilation, I tried to find the hex file, but the link provided in the blog post to download the hex is not working. please see the screenshot of PPK II.
To measure the current consumption, you need to program the RuuviTag using devkit or other SWD programmer and then disconnect it. This way you can ensure no current is leaking to devkit or back.
I generally have two tags, one which I use for firmware development on top of devkit and one which has soldered wires to battery connector for power connection and nothing else. I then measure the power consumption on the tag dedicated for power measurements.
