Yes, I have disconnected and turned off the bluetooth on the laptop just to be sure. The URL is short and https - I have tried both with the https:// prefix and without.
But from your reply I infer that it should work and has been seen working on the basic tag?
The URL has to be resolvable and have a valid SSL certificate (let’s encrypt is fine) to show up as an Android Nearby notification. Have you tried to scan for the URL using for example a Physical Web app?
I have tried several URLs, all should meet the requirements. App used for scanning is the same Chrome that sees Ruuvitags with Eddystone firmware without problems.
I just tried the example on https://www.espruino.com/Puck.js+Eddystone with my RuuviTag basic on Espruino 1.91_450 with no problems. The date of my version is 10th of March, I’ll check how it goes on 1.91_447 (13th of April).
Edit: I just tried on latest Espruino without problems. Could you please share the exact code you’re using so I can try to replicate the problem?
I’m using this code to advertise temperature measured from OneWire device, it works:
function onInit()
var ow = new OneWire(4);
device = ow.search()[0];
if (device===undefined)
print(“No OneWire devices found”);
else
print(“device:”+device);
