Eli tilasin robottiautosetin dx.com sivuilta http://www.dx.com/p/diy-intelligent-tortoise-smart-wheel-robot-module-173668#.VHmmVTGsX_4
Kasasin auton ja kopion koodin tekstitiedostosta ohjelmaan. Kun alan kääntämään koodia tulee virheilmoituksia…
xception in thread “Thread-14” java.lang.StackOverflowError
at java.util.regex.Pattern$Loop.match(Unknown Source)
at java.util.regex.Pattern$GroupTail.match(Unknown Source)
at java.util.regex.Pattern$BranchConn.match(Unknown Source)
at java.util.regex.Pattern$CharProperty.match(Unknown Source)
at java.util.regex.Pattern$Branch.match(Unknown Source)
at java.util.regex.Pattern$GroupHead.match(Unknown Source)
Osaako kukaan neuvoa tämmöstä aloiteelijaa, että missäköhän vika voisi olla. Laitan alle vielä koodin…
# Include <IRremote.h>
# Include <Servo.h>
/ / *********************** Defined motor pin ********************* ****
int MotorRight1 = 5;
int MotorRight2 = 6;
int MotorLeft1 = 10;
int MotorLeft2 = 11;
int counter = 0;
const int irReceiverPin = 2; / / OUTPUT signal of the infrared receiver is connected to the pin 2
/ / *********************** Set detected IRcode ****************** *******
long IRfront = 0x00FFA25D; / / forward code
long IRback = 0x00FF629D; / / Back
long IRturnright = 0x00FFC23D; / / turn right
long IRturnleft = 0x00FF02FD; / / turn left
long IRstop = 0x00FFE21D; / / Stop
long IRcny70 = 0x00FFA857; / / CNY70 self-propelled mode
long IRAutorun = 0x00FF906F; / / ultrasound self-propelled mode
long IRturnsmallleft = 0x00FF22DD;
/ / ************************* Defined CNY70 pin ******************* *****************
const int SensorLeft = 7; / / left sensor input pin
const int SensorMiddle = 4; / / the Sensor input pin in
const int SensorRight = 3; / / right sensor input pin
int SL; / / left sensor status
int SM; / / in the sensor state
int SR; / / right sensor status
IRrecv irrecv (irReceiverPin); / / the definition IRrecv object to receive infrared signals
decode_results results; / / decoding results on decode_results structure result variable
/ / ************************* Definition ultrasound pin ****************** ************
int inputPin = 13; / / define the ultrasound signal reception pin rx
int outputPin = 12; / / define the ultrasonic signal transmitter pin 'tx
int Fspeedd = 0; / / in front of the distance
int Rspeedd = 0; / / the right distance
int Lspeedd = 0; / / left distance
int directionn = 0; / / = 8 = 2 Left = Right = 6
Servo myservo; / / set myservo
int delay_time = 250; / / servo motor steering stability time
int Fgo = 8; / / forward
int Rgo = 6; / / turn right
int Lgo = 4; / / turn left
int Bgo = 2; / / reversing
/ / ************************************************ ******************** (SETUP)
void setup ()
Serial.begin (9600);
pinMode (MotorRight1, OUTPUT); / / pin 8 (PWM)
pinMode (MotorRight2, OUTPUT); / / pin 9 (PWM)
pinMode (MotorLeft1, OUTPUT); / / pin 10 (PWM)
pinMode on (MotorLeft2, OUTPUT); / / pin 11 (PWM)
irrecv.enableIRIn (); / / start infrared decoding
the pinMode (SensorLeft, INPUT); / / define the left sensor
pinMode (SensorMiddle, INPUT) ;/ / definition sensor
the pinMode (SensorRight, INPUT); / / define the right sensors
digitalWrite (2, HIGH);
pinMode (inputPin, INPUT); / / definition ultrasound input pin
pinMode (outputPin, OUTPUT); / / definition ultrasound output pin
myservo.attach (9); / / define the servo motor output 5th pin (PWM)
/ / ************************************************ ****************** (Void)
void advance (int a) / / forward
digitalWrite (MotorRight1, LOW);
digitalWrite (MotorRight2, HIGH);
digitalWrite (MotorLeft1, LOW);
digitalWrite (MotorLeft2, HIGH);
delay (a * 100);
void right (int b) / / turn right (single wheel)
digitalWrite (MotorRight2, LOW);
delay (b * 100);
void left (int c) / / turn left (single wheel)
digitalWrite (MotorLeft2, LOW);
delay (c * 100);
void turnR (int d) / / turn right (two-wheeled)
digitalWrite (MotorRight1, HIGH);
delay (d * 100);
void turnL (int e) / / turn left (two-wheeled)
digitalWrite (MotorLeft1, HIGH);
delay (e * 100);
void stopp (int f) / / stop
delay (f * 100);
void back (int g) / / Back
digitalWrite (MotorLeft2, LOW);;
delay (g * 100);
void detection () / / measuring three angles (front left right)
ask_pin_F (); / / read in front of the distance
if (Fspeedd <10) / / If the front of the distance is less than 10 cm
stopp (1); / / Clear the output data
back (2); / / back 0.2 seconds
if (Fspeedd <25) / / If the front of the distance is less than 25 cm
ask_pin_L (); / / read the left distance
delay (delay_time); / / wait for the servo motor stable
ask_pin_R (); / / read the right distance
if (Lspeedd> Rspeedd) / / if the left distance is greater than the right distance
directionn = Lgo; / / go left
if (Lspeedd <= Rspeedd) / / if the left distance is less than or equal to the right side of the distance
directionn = Rgo; / / right away
if (Lspeedd <15 && Rspeedd <15) / / if the left distance and right distance are less than 10 cm
directionn = Bgo; / / walk backward
else / / add, such as in front of more than 25 cm
directionn = Fgo; / / forward
void ask_pin_F () / / measure out the front of the distance
myservo.write (90);
the digitalWrite (outputPin, LOW); / / let the ultrasonic transmitter Low Voltage 2¦Ìs
delayMicroseconds (2);
the digitalWrite (outputPin, HIGH); / / ultrasonic transmitting high voltage 10¦Ìs, at least 10¦Ìs
delayMicroseconds (10);
digitalWrite (outputPin, LOW); / / maintain ultrasonic transmitter low voltage
float Fdistance = pulseIn (inputPin, HIGH); / / read differential difference
Fdistance = Fdistance/5.8/10; / / time to distance distance (unit: cm)
Serial.print ("F distance:"); / / output distance (unit: cm)
Serial.println (Fdistance); / / display distance
Fspeedd = Fdistance; / / distance read Fspeedd (speed)
void ask_pin_L () / / measure out the left distance
myservo.write (177);
delay (delay_time);
float Ldistance = pulseIn (inputPin, HIGH); / / read differential difference
Ldistance = Ldistance/5.8/10; / / time to distance distance (unit: cm)
Serial.print ("L distance:"); / / output distance (unit: cm)
Serial.println (Ldistance); / / display distance
Lspeedd = Ldistance; / / distance reads Lspeedd (left-speed)
void ask_pin_R () / / measure out the right side of the distance
myservo.write (5);
delay (delay_time);
float Rdistance = pulseIn (inputPin, HIGH); / / read differential difference
Rdistance = Rdistance/5.8/10; / / time to distance distance (unit: cm)
Serial.print (the R distance: "); / / output distance (unit: cm)
Serial.println (Rdistance); / / display distance
Rspeedd = Rdistance; / / distance read into Rspeedd (right speed)
/ / ************************************************ ****************************** (LOOP)
void loop ()
SL = digitalRead (SensorLeft);
SM = digitalRead (SensorMiddle);
SR = digitalRead (SensorRight);
/ / ************************************************ *************************** normal remote mode
if (irrecv.decode (& results))
{/ / Decoding successful, receive a set of infrared signals
if (results.value == IRfront) / / forward
advance (10) ;/ / forward
if (results.value == IRback) / / Back
back (10) ;/ / Back
if (results.value == IRturnright) / / right turn
right (6); / / turn right
if (results.value == IRturnleft) / / left turn
left (6); / / turn left);
if (results.value == IRstop) / / stop
/ / ************************************************ black self-propelled mode the *********************** cny70 mode: LOW white:
if (results.value == IRcny70)
while (IRcny70)
if (SM == HIGH) / / in the sensor in the black areas
if (SL == LOW & SR == HIGH) / / left black right white to turn left
analogWrite (MotorLeft1, 0);
analogWrite (MotorLeft2, 80);
else if (SR == LOW & SL == HIGH) / / left white right black, turn right
analogWrite (MotorRight1, 0) ;/ / turn right
analogWrite (MotorRight2, 80);
else / / both sides are white, straight
analogWrite (MotorLeft1, 200);
analogWrite (MotorLeft2, 200);
analogWrite (MotorRight1, 200);
analogWrite (MotorRight2, 200);
else / / in the sensor in the white areas
if (SL == LOW & SR == HIGH) / / white left black right, quick left turn
else if (SR == LOW & SL == HIGH) / / left white right black, quick right turn
else / / are white, stop
irrecv.resume ();
Serial.println (results.value, HEX);
break;
results.value = 0;
/ / ************************************************ the *********************** ultrasound self-propelled mode
if (results.value == IRAutorun)
while (IRAutorun)
myservo.write (90); / / the servo motors regression ready position ready for the next time measurement
detection (); / / measure the angle and the judgment to where to move in one direction
if (directionn == 8) / / if directionn (direction) = 8 (forward)
irrecv.resume ();
break;
results.value = 0;
advance (1); / / normal ahead
Serial.print ("Advance"); / / display direction (forward)
Serial.print ("");
if (directionn == 2) / / if directionn (direction) = 2 (reverse)
irrecv.resume ();
break;
results.value = 0;
back (8); / / reverse (car)
turnL (3); / / move slightly to the left (to prevent stuck in a dead alley)
Serial.print ("Reverse"); / / display direction (reverse)
if (directionn == 6) / / if directionn (direction) = 6 (turn right)
irrecv.resume ();
break;
results.value = 0;
back (1);
turnR (6); / / turn right
Serial.print ("Right"); / / display direction (turn left)
if (directionn == 4) / / if directionn (direction) = 4 (turn left)
irrecv.resume ();
break;
results.value = 0;
back (1);
turnL (6); / / turn left
Serial.print ("Left"); / / display direction (turn right)
irrecv.resume ();
break;
results.value = 0;
else
irrecv.resume (); / / continue to the next set of infrared signals received
