Some of our users had been wondering how to adjust the brightness level for the Ruuvi Air main LED, that is used to indicate the current air quality level. This adjustment is supported in firmware and can be set using the pinhole button at the bottom of the Ruuvi Air.
this function could use an upgrade. Every power interruption will reset the brightness to default, which is a pain for a Ruuvi air in the bedroom, for instance
This should have already been fixed in v1.3 firmware, which version you are running?
it says βvery oldβ LOL
thanks
