Add new sensor
After a heavy rain shower, my Ruuvi sensor stopped working. Now, when I look at the sensor, it functions.
When I start it, I see a red light, and after a while, that turns green. I also see a green LED every few seconds. I cannot add it using “add a new sensor”. Is there another way to get it working
Hi @rbouwman ,
Thank you for your message and sorry for troubles.
You mentioned that you look at the sensor if functions, does it mean that it gives you measurements to Ruuvi Station normally?
Faint green blinking green is indicating normal operation mode. If you already have this sensor added to Ruuvi Station, you will not see it in Add a New Sensor page. See if there are any new measurements arriving to the sensor page and if not, please take your RuuviTag out from the protective case, take clear closeup photos of the circuit board and send to support@ruuvi.com along with the description and we can help troubleshoot this situation.
