Short intro: hass is home automation software for raspberry pi. It has a lot of functionality with bunch of stuff but ruuvitag reading was not implemented so I decided to do it myself.
Just got reading values from two weather station ruuvi beacons working.
Screenshot from hass ui (fought with sensors, that is why measurement data history is pretty patchy)
If someone has idea how things could be handled smarter than having one copy of python file per beacon and/or value that needs to be read I would be grateful.
Updated python script yesterday. Now there are 3 modes:
Batch - just put list of ruuvitag MACs and measurements from each are returned separated by :
Measurements from single ruuvitag, values are separated by :
Single measurement of single ruuvitag, define temp/pressure/humidity and only single value is returned
Added also configuration help to github for homeassistant. You need to get all the data with single command line execution in order to keep homeassistant environment happy. So you’ll add one sensor that includes all of the values and create a template which separates all the value to separate sensors.
Don’t mind the readings, they are accurate only after 15:00 today when all started finally working well.
Disclaimer: there might be issues with homeassistant web ui. Probably full reboot of raspberry due to power outage might have something to do with it. Or then not. Don’t know.
Hello…the simplest solution is obviously just door sensors configured to send notifications when the doors are opened in the time window when they typically arrive home from school. However, that will trip unnecessarily if my wife arrives home in that time window on her days off and wouldn’t tell me if each individual child has arrived home, just that someone entered.
Edit: that approach has at least almost all possible sensors from ruuvitag covered and uses bleson which is worlds apart from previous approaches with its reliability.
I have python venv installation and installed dependencies manually.
Snips from my installation notes, newest one on top:
Add groups
Add rest of the sensors into configuration
Edit configuration and test if it works
-> config error because of missing dependencies
-> hope for the best and restart hass
-> works god dammit on first try!
Git clone ruuvi hassio https://github.com/ruuvi-friends/ruuvi-hass.io -> Symlink to correct folder (ln -s ./ruuvi-hass.io/custom_components ./ in conf folder -> Fight with git -> settle so that syncing the symlink only works
Install bleson https://github.com/TheCellule/python-bleson -> Permissionerror (expected) -> Add bleson group [useless] -> Put homeassistant user there [useless] -> Which python3 [in venv] -> /srv/homeassistant/bin/python3 -> readlink -f /srv/homeassistant/bin/python3 -> /usr/bin/python3.8 -> sudo setcap cap_net_raw,cap_net_admin+eip add_path_here -> Aaand it works!
Install automatic start systemd stuff
Install python virtual environment homeassistant
with dedicated homeassistant username etc…
Set specific fixed ip for nuc to router dhcp server
just reinstalled hass.io, and this integration to clean installation. And now I get this error:
Platform error: sensor
Sitaatti
Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/config.py”, line 815, in async_process_component_config
platform = p_integration.get_platform(domain)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 401, in get_platform
cache[full_name] = importlib.import_module(
File “/usr/local/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 783, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/config/custom_components/ruuvi/sensor.py”, line 8, in
from homeassistant.const import TEMP_CELSIUS, UNIT_PERCENTAGE, PRESSURE_HPA
ImportError: cannot import name ‘UNIT_PERCENTAGE’ from ‘homeassistant.const’ (/usr/src/homeassistant/homeassistant/const.py)
Where did you install the sensor.py from? If you use the version from my github branch, it should work. It seems that author has not yet accepted my pull request to official branch.
I used to have working raspberry Hass.io system with Ruuvitag add-on version 0.3.0. After Hass.io system update (now HassOS 4.14 and Supervisor 249) Ruuvitag add-on is not working anymore.
I request simple and precise instructions how to get Ruuvitags working again. Instructions in this thread are too complex for me…
Or is somewhere working add-on version for HassOs / raspberry system?
IMHO you should always wait before updating homeassistant if you are not able to immediately troubleshoot after installing the update. There can be major changes to configuration yaml logics also and similar during the updates.
They are moving really fast with the platform doing major updates and improvements all the time with small team. It means some things outside core stuff will break down occasionally for a while.
