Hi! I correctly uploaded and installed Espruino firmware inside my Ruuvitag, then using the IDE on browser I started coding. My goal is to publish environmental data every 15 minutes. Because the original behaviour post over BLE too much data every seconds.
What is the function to post over BLE?
Here is my code:
// require Ruuvitag library
// declare minutes
var minutes = 15;
// function required for start code every reboot (saved on ROM)
function onInit() {
// enable environment data
Ruuvitag.setEnvOn(true);
// disable accelerometer data
Ruuvitag.setAccelOn(false);
// publish data every 15 minutes over BLE
setInterval(function() {
// send data over BLE ?!?!?!
}, 1000*minutes);
Thank you very much!
