Wall u-value measurement
Hello everyone,
I want to measure the heat capacity β€œU” (thermal performance) of a wall in order to perform a heat loss calculation.
My plan is to place three RuuviTag Pro sensors as follows:
  1. One mounted on the interior wall surface.
  2. One measuring the ambient indoor air temperature.
  3. One mounted on the exterior wall surface.
I intend to use thermal paste between the wall surfaces and the sensors to ensure better contact and more accurate surface temperature readings. I will then extract the measurement data directly from the .xml files generated by each sensor for analysis.
Has anyone attempted a similar setup? I would love to hear your thoughts, feedback, or impressions on how reliable this method is.
Thanks in advance!
Hi @GeorgiosT ,
My initial thought is that standard RuuviTag sensors are not really compatible with this experiment, since they’re designed to measure air temperature, not surface.
There is a model with external temperature sensor, which might potentially fit this task better. https://ruuvi.com/products/ruuvitag-external-temperature-sensor/
