The ruuvitag works fine and I can see the Weather Station.
Used Android Nearby for this.
I notice I can’t use Nearby for configuration.
So I installed nRF Beacon for Eddystone.
But I don’t see the ruuvitag (using SCAN).
So following the setup I tried to update the firmware.
But I’m not able to.
I did press B+R and the red led is on.
I don’t see ruuvitag in nrF Beacon for Eddystone after SCAN.
Tried several times.
My Ruuvi also appears to work and I can see the Weather Station.
I pressed B+R and the red led is on.
Ruuvi shows in nrF Beacon A “Misc” or “RuuviBoot” or “BLEsmart_000001100F07…” after SCAN.
None will BOND
In settings bluetooth they will show up as “RuuviBoot” or “Misc” or "BLEsmart_000001100F07…"
but pairings are “Rejected” then “Try again, Yes?No”
I have checked the instructions here:
EDDYSTONE™RuuviTag has sensors, yes, but it’s…
There are several ways to configure the beacon. For example:Web Bluetooth Configuration Tool…(doesn’t show up during SCAN)
To enter configuration mode…The default unlock code is: 0x00112233445566778899aabbccddeeff…(Video DOES NOT HAVE CLOSED CAPTIONS AND I AM DEAF)
This is how it’s done:(Video DOES NOT HAVE CLOSED CAPTIONS AND I AM DEAF)
Never the less, I downloaded, 20170118-eddystone.zip
Question 1) What operating system does this run on?
Question 2) If I have the appropriate OS, does it need to be compiled or something?
Question 3) Only my Phone has bluetooth. Is there anyway to run this on Android?
