I am keen to attempt a simple Xcode experiment to read acceleration data from the Ruuvi pro and dislay it on an iphone. I would like to manipulate the data and display it but havent got that far.
I have followed the tutorial and installed Cocoapods ok. I can then modify the Podfile ok. When I run “pod install” I do not have the result expected. It is below
Last login: Sun Feb 6 15:02:09 on ttys000
trevorbird@192-168-1-103 ~ % pod install
Analyzing dependencies
Downloading dependencies
Generating Pods project
Integrating client project
/Library/Ruby/Gems/2.6.0/gems/ethon-0.15.0/lib/ethon/curls/classes.rb:36: [BUG] Illegal instruction at 0x0000000104880000
ruby 2.6.8p205 (2021-07-07 revision 67951) [universal.arm64e-darwin21]
– Crash Report log information --------------------------------------------
- See Crash Report log file under the one of following: *
* ~/Library/Logs/DiagnosticReports *
* /Library/Logs/DiagnosticReports *
- for more details. *
*Don’t forget to include the above Crash Report log file in bug reports. *
– Control frame information -----------------------------------------------
c:0043 p:---- s:0241 e:000240 CFUNC :getdtablesize
c:0042 p:0050 s:0237 e:000236 CLASS /Library/Ruby/
and lots of other lines of Control Frame information.
I figure I must be doing something very wrong. I was having little success with the podfile set out in the tutorial like this
platform :ios, ‘10.0’
use_frameworks!target ‘RuuviTag’ do
pod ‘BTKit’, ‘~> 0.0.21’
end
It seemed to have a syntax error until changed to this
use_frameworks!
end
I have changed from textedit to sublime text in case some hidden access codes appeared but that has not helped.
I changed to what I think is the latest version like this
platform :ios, ‘13.0’
use_frameworks!
pod ‘BTKit’, ‘~> 0.3.2’
end
Anyway I am struggling to get past first base with this tutorial and would like to know if anything is obviously wrong to other programmers. I would like to get to the stage of producing a .xcworkspace file that I can launch from but at this tage havent got that far.
Kind regards and thanks for reading this far,
Trevor
