I have tags monitoring several beehives. Iād really like to be able to set a user defined y-axis range so that I can properly compare charts in the dashboard at a single glance without having to inspect the ranges used. The variable range makes all changes in temperature look important, even if they are just minor changes within 1 or 2 degrees.
With user defined y-axis for each chart I could have a consistent look allowing more simple visual monitoring.
Thanks
Richard
