Ruuvi Station iOS App v1.1.1(286) is available for public beta testers. We have added new features, performed several major and minor enhancements, and fixed critical and minor bugs. Please install the beta and share your valuable feedback.
New Feature:
We have improved the onboarding experience with the addition of Ruuvi Cloud which lets users sign in to their cloud account while onboarding.
Enhancements:
Show checkmark beside the selected item on the settings.
The one-time code text field is now replaced with intuitive boxes.
Sensor name editing text field now changed into a popup that allows users to change names comfortably.
No sensors screen is unified with other platforms.
Syncing from GATT now shows progress with the number of data points fetched.
A low battery level warning is shown at the time of firmware update if the battery level is low.
Improved user experience on sensor sharing screen.
Other minor enhancements.
Bug Fixes:
Fixed an issue where the first sensor card may not be updating properly.
Ruuvi Station iOS v1.1.3(299) is submitted for the beta testers. This version addressed the issue where Gatt sync may not be syncing the historical data properly.
Important: Please help test the Bluetooth connection as well because the latest iOS (15.5) may have some bugs which affect the Ruuvi Station.
Once the beta is approved a notification will be sent out to you. Please share your feedback so that we can improve the app. Thank you.
Ruuvi Station iOS v1.2.0(302) is available for the public beta testers. This is a major update since in this update we have brought simple widget on the iOS app. We would like to ask you to install the beta, test and shared your feedback so that we can improve the experience.
Features:
Simple Configurable Widget.
Enhancements
Removed language selection from the app settings and supported Apple’s per-app language settings approach.
Bug fixes:
Fixed an issue where virtual sensors may show the wrong name.
Fixed an issue where updating the virtual sensor’s name or location may not immediately affect the sensor settings screen.
Fixed an issue where German localization may not be working properly on the onboarding screen.
Note: After updating the app, please be informed that the app has to be launched at least once to make the widget available in the widget gallery.
Ruuvi Station iOS v1.3.0(315) is available for public beta testers. This is a major update with some big improvements in performance, enhancements, and several bug fixes and optimizations. We would like to ask you to install the beta, test it, and share your feedback so that we can improve the experience.
Features:
Added measurement precision settings that allow users to set the level of precision they want to see for the measurement data.
Enhancements
Optimised and improved the cards page sync and scrolling experience using a newly implemented API.
Rewritten the firmware upgrade flow for the tags having old firmware like Data Format 3 which enables a smooth experience than ever.
Keyboard now shows the email layout while typing the email address on the tag share screen.
App stores all measurements now when the app is in the foreground which enables the live chart update.
The users are asked to share reviews complying with the guidelines from Apple.
Sensor now shows the last measurement beyond 10 days.
Offset calibrated values now affect the UI immediately after setting up. Earlier it was used to sync on the next cloud sync or BT measurement.
Added “What To Measures with Ruuvi?” option on the menu.
Unified the CSV file format with other platforms.
Added the battery capacity indicator on the tag settings page.
Unified the font stylings across the application.
Shows a warning message when the user tries to leave the chart page while a sync is in progress or cancels an ongoing sync.
Updated the styles of the about page.
Added a darker layer behind the chart to make it more comfortably visible on top of different types of background.
Updated icons on the card page to make it look better and unified with other platforms.
Removed the ability to add new “Virtual Sensors”. However, already added sensors will be functioning correctly until further updates.
Added “My Ruuvi Account” option in the menu which contains an option to delete the Ruuvi Cloud account.
Bug fixes:
Fixed an issue where getting firmware version on tag settings screen stalled or never times out.
Fixed an issue where trying to claim a tag may be throwing an SQL error.
Fixed an issue where BT seems to be fetching data more frequently than it should.
Fixed an issue where tapping on the widget may not be opening the associated card the first time.
Fixed an issue where the GATT sync button was not visible after switching back from the cloud mode.
Fixed an issue where the login verification code may be attempting to verify the code in each key press.
Fixed an issue where sensors without cloud records may be visible for selection on the widget.
Fixed an issue where tag may be showing older data from the cloud even the newer data is already available from the BT.
Fixed an issue where humidity and pressure calibration settings may not be appearing on the tag settings screen sometimes.
Fixed an issue where changing the language may create unexpected behavior such as signing out not removing the cards or the sign-out button not being visible and so.
Fixed an issue where the clear/sync button on the charts page was visible for tags not nearby or received any BT message.
Ruuvi Station iOS v1.3.0(320) is available in the public beta.
This build address the crashes reported on build 319. Also, it brings improvements to the charts page.
Please be noted that - the draw dots feature is hidden from the charts settings for the time being to maintain a good performance across devices. We are working on bringing it back soon.
Ruuvi Station iOS v1.3.1(327) is available in the public beta. We are always working to improve Ruuvi Station and provide the best user experience possible. This update brings new features, several major and minor enhancements, and bug fixes.
Features:
Lockscreen Widget with all supported sizes is now available for devices with iOS 16.
Alert settings are now more compact with being expandable on tap.
Enhancements:
Removed warning alert indicator for the humidity on the card page.
Bluetooth disabled alert has a settings button to open system or app settings.
‘Connection’ section on the sensor setting page is cleaned up, adding more context.
Make background scanning settings sync with the sensor pairing states.
Show widgets time format based on the format on the device.
The firmware update section is now made visible for both cloud and local sensors. Although, the - update would require the tag to be in the range of the device.
The sensor setting page shows the owner’s name for the claimed tag without making any attempt to claim.
Bug Fixes:
Fixed an issue where GATT sync text might be overlapping or visible under the action buttons.
Fixed an issue where charts may show a blank page when no data is available.
Fixed an issue where failed GATT sync shows a contextless error message.
Fixed an issue where some of the columns on CSV file may showing extra quotes.
Fixed an issue where fetching the sharee list might be blocking the whole UI due to poor connection.
Fixed an issue where inactive alerts might be reset when the user signs in.
Performance Improvements:
Addressed issues related to the app crashing or lagging in the older devices or devices with iOS 15.7.
Big update for Ruuvi Station iOS . Version 2.0 is available for public beta testers. This is a major update with big improvements and new features, and addresses some important performance issues. We would appreciate any feedback including the look and feel as well as the obvious bug reports.
New welcome tour gives you a better overview of the app features and improvements in 2.0
New sign in has been revamped to improve sign in and sign up
Completely redesigned dashboard with a new fresh look and ability to show or hide sensor images
Push notification alerts are now available for Ruuvi Gateway users with a valid Ruuvi Cloud Basic or higher subscription level
Background image selector was redesigned including a selection brand new default images
Overall design of the app was improved and unified
App has now been fully translated for English, Finnish, Swedish, French and German languages
Lots of minor fixes and improvements were included in this new major version update
Minimum requirement for running Ruuvi Station is now iOS 14
Uusi esittely antaa sinulle paremman yleiskuvan sovelluksen ominaisuuksista ja parannuksista versiossa 2.0
Uudistunut kirjautumissivu helpottaa ohjelmaan sisäänkirjautumista ja rekisteröitymistä
Täysin uudistunut koontinäyttö, jossa parannettu ulkoasu ja mahdollisuus näyttää tai piilottaa anturikorttien taustakuvat
Push-hälytysviestit ovat nyt saatavilla Ruuvi Gatewayn käyttäjille, joilla on voimassa oleva Ruuvi Cloud Basic tai parempi tilaustaso
Uudistunut taustakuvavalitsin, joka sisältää myös valikoiman upouusia oletuskuvia
Ohjelman ulkoasuun liittyviä parannuksia ja yhdenmukaistuksia eri alustojen välillä
Sovellus on nyt täysin käännetty englanniksi, suomeksi, ruotsiksi, ranskaksi ja saksaksi
2.0 versiopäivityksessä mukana paljon pieniä korjauksia ja parannuksia
Ruuvi Station iOS v 2.3.0 is available for the public beta testers. This update brings several bug fixes and improvements.
En:
Users are now able to add sensors to Ruuvi Station and view sensor information using near-field communication (NFC) when supported by device
Claiming sensor ownership is now suggested on Sensor Settings page for new sensors that are not yet claimed
Users can now rename sensors from Dashboard 3-dots menu
Pull down gesture can now be used on dashboard to synchronise latest data from Ruuvi Cloud
New images for welcome screens
Fonts and icon sizes have been improved on sensor cards and dashboard
Other minor improvements and bug fixes
Fi:
Käyttäjät voivat nyt lisätä antureita Ruuvi Stationiin lyhyen kantaman langattoman teknologian (NFC) avulla, mikäli laite tukee tätä
Antureiden omistajuuden merkitsemistä ehdotetaan nyt anturin asetukset sivulle mentäessä uuden anturin lisäämisen jälkeen, mikäli omistajuutta ei ole vielä merkitty
Antureita voi nyt nimetä myös koontinäytön kolmipistevalikosta
Voit nyt synkronoida uusimmat mittaustulokset koontinäytöllä vetämällä alas näytöllä
Käyttöönottoesittelyn kuvia päivitetty
Fontteja ja kuvakkeiden kokoja parannettu sekä täydellä anturikortilla että koontinäytöllä
Ruuvi Station iOS app 2.3.2 hotfix build is now available on TestFlight. It should help with crashing when app is receiving new Bluetooth advertisements from RuuviTag sensors. Some users have reported these crashes on 2.3.0 and 2.3.1 app versions. Let us know your feedback. Thanks!
Ruuvi Station iOS v 2.4.0 is available for the public beta testers. This update brings several bug fixes and improvements.
En:
Users are now able to limit alert notifications to receive only 1 alert notification per hour from local Bluetooth sensors
Users with Pro or higher subscription level are able to set an alert to be shown when sensor has not been updated within a specific time from Ruuvi Cloud using Cloud Connection alert
History view now has selections to view 1-12 hours sensor history
Measurement Minimum/Maximum/Average is now shown on history view according to chosen timeline
Navigation was improved for browsing between Full Image sensor cards and History views
Fixed ability to show NFC scanning option when no nearby sensors are detected via Bluetooth
Added support to receive language-formatted push messages and emails in the future
Fi:
Käyttäjät voivat nyt rajoittaa hälytysilmoituksia yhteen hälytykseen tunnissa kun hälytyksen lähde on Bluetooth
Pro ja korkeamman tilaustason käyttäjät voivat nyt saada hälytyksiä antureista, joiden tietoja ei ole päivitetty Ruuvi Cloud -pilvipalveluun tietyn ajan sisään asettamalla Yhteys pilveen -hälytyksen
Historiasivulla on nyt valittavissa 1-12 tunnin mittaushistoria
Mittausten Minimi/Maksimi/Keskiarvo näytetään nyt anturin historia -sivulla valitun näkymän mukaan
Navigointia korttien välillä parannettu täydellä anturikortilla ja historianäkymässä
Korjattu bugi joka esti NFC-vaihtoehdon näyttämisen silloin, kun vielä lisäämättömiä antureita ei ollut Bluetoothin kuuluvuusalueella
