has anybody experiences in running Ruuvi above specs i.e. ++85C ambient?
We are making some temp cycling in an environment chamber having three (3) tags in there and raspberry listening to them.
One of the tags froze just below +87C, did we run out of scale or ruin the tag?
It seems anyhow that the power supply temp range has been exceeded long time ago, manufacturer states “usable temperature range -20…+70C”
You should use extended temperature range batteries if you need to use RuuviTags at high temperatures, email sales@ruuvi.com to order special batteries.
