Do you have another “host” computer? desktop/ laptop/tablet?
running Mac OS/IOS/windows/linux.
There are additional tools for these platforms I can recommend that might help you determine/confirm the addresses. Discovering MAC addresses
From a console (terminal/ ssh / putty ) on/to the Raspberry pi you can query you existing database using influx
A command similar to:
SELECT mac, 32 + last(temperature) * 9 / 5, humidity FROM ruuvi.autogen.ruuvi_measurements GROUP BY mac ORDER BY time ASC TZ('America/New_York')
Here’s the results of the curl command in the link that you provided:
{“results”:[{“statement_id”:0,“series”:[{“name”:“ruuvi_measurements”,“tags”:{“mac”:“C82B6B37B5F9”},“columns”:[“time”,“mac”,“last”],“values”:[[“2020-02-08T16:32:41.783Z”,“C82B6B37B5F9”,20.83]]}]}]}
This is related to a rare issue fixed already in RuuviCollector v0.2.4 (latest version at the moment is v0.2.6), you should update your version of RuuviCollector, which should resolve at least some of the issues
It depends on which exact method you used for the installation for the first time, but in general the process is simply just replacing the jar file with a new version and restarting the collector. If you downloaded the prebuilt jar, you can just download a newer one from the releases page. If you instead built RuuviCollector yourself, you need to just acquire the latest sources (ie. the same way you did before) and rebuild.
Active: failed (Result: exit-code) since Sun 2021-02-14 12:43:17 CST; 2min 57s ago
Main PID: 5116 (code=exited, status=1/FAILURE)
Feb 14 12:43:17 svp-rpi systemd[1]: ruuvicollector.service: Service RestartSec=100ms
expired, scheduling restart.
Feb 14 12:43:17 svp-rpi systemd[1]: ruuvicollector.service: Scheduled restart job, restart counter is at 5.
Feb 14 12:43:17 svp-rpi systemd[1]: Stopped RuuviCollector Service.
Feb 14 12:43:17 svp-rpi systemd[1]: ruuvicollector.service: Start request repeated too quickly.
Feb 14 12:43:17 svp-rpi systemd[1]: ruuvicollector.service: Failed with result ‘exit-code’.
Feb 14 12:43:17 svp-rpi systemd[1]: Failed to start RuuviCollector Service.
