Powering Ruuvi Gateway from a 12V DC system (sailboat)
Title: Powering Ruuvi Gateway from a 12V DC system (sailboat)
Hi everyone,
I’m considering buying a Ruuvi Gateway to monitor several RuuviTags on my sailboat.
Since the boat runs on a 12V DC electrical system, I’d like to power the Gateway without using a 230V inverter.
Can the Gateway be safely powered using a 12V-to-5V USB-C DC-DC converter? Are there any specific voltage, current, or power requirements I should consider?
Has anyone tried a similar setup?
Thanks for your help!
Hi @jmeischner
Thanks for your question!
Yes, you can power Ruuvi Gateway from your boat’s 12 V system using a suitable DC-DC USB converter, without a 230 V inverter.
Please choose a converter with:
Regulated 5 V DC output through USB-C.
At least 1 A output capacity (5 W). A 2 A or 3 A supply is also fine—the Gateway draws only the current it needs. Ruuvi’s power guidance specifies at least 1 A peak capacity.
An input voltage range suitable for your boat’s electrical system, including when the batteries are charging.
Do not connect 12 V directly to the Gateway’s USB-C port. For installation onboard, use a suitably fused supply and keep the Gateway and converter protected from moisture.
For remote monitoring, the Gateway will also need an internet connection via Wi-Fi or Ethernet, for example through an onboard mobile router.
Hej Marko,
thanks for the answer. Then I will give it a try :+1:
