I want to use it to measure the speed of my bike as detailed as possible. I know that there are sensors (e.g. from wahoo) that are capable of returning the RPM, but they are not very precise (e.g. a sudden stop is recorded with a lag of a few seconds).
One way would be hall -sensor soldered to ruuvitag within the enclosure, custom firmware to include its measurements and add regular bike computer magnet to your wheel. Then just position ruuvitag accordingly.
This approach also have delays because there needs to be some kind of averaging for the RPM just like with cadence meters to stop numbers bouncing all around all the time and keep it readable if you want to monitor stuff during your ride. You need multiple rotations measured before you can determine what roughly is the sane value and not just any random variation that gives wrong readings.
Thanks for your answer!
Interesting approach - is there some kind of variation where delays would be close to 0? I’d like to have the readings in near realtime; just like a tachometer in a car.
The most obvious one would be to have multiple signals per single revolution. So if you can space 4 magnets symmetrically enough to wheel you get 4 samples per resolution and then you can have averaging and wait couple pulses before presuming that loss of pulses is because rotation has stopped completely.
