Hi.
We are having trouble to read the correct values of Battery. What can be the issue?
Current data protocol is No. 3
Hello, what you are using to parse the readings?
Below you can se the RAW values in hex and parsed values…
I checked the last four digit in HEX, and it is around 3.000 voltage, I will try to correct. sorry for that…
Found RuuviTag D1:AB:59:2A:43:C5
Hex: 990403531B3BC5AD000B000F04020BEF
RSSI: -54 dBm
Temperature: 27.59 C
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 61.195 V
Found RuuviTag F6:81:98:70:73:52
Hex: 99040368060FC5B0FFC6FFD803F60C13
RSSI: -89 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 4.876 V
Hex: 990403531B3BC5AC000A001104030BEF
RSSI: -51 dBm
Humidity: 41.50 %
Pressure: 94229 Pa
Voltage: 61.195 V
Found RuuviTag D7:C6:3D:DF:DA:F5
Hex: 990403471954C5C9FFF7FFF2040B0C19
RSSI: -31 dBm
Temperature: 25.84 C
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 6.412 V
Hex: 990403531B3AC5AC0008001204050BF5
RSSI: -55 dBm
Temperature: 27.58 C
Humidity: 41.50 %
Pressure: 94229 Pa
Voltage: 62.731 V
Hex: 990403531B3AC5AD0007001104040BE9
RSSI: -52 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 59.659 V
Hex: 990403471954C5C8FFF7FFF1040C0C07
RSSI: -27 dBm
Humidity: 35.50 %
Pressure: 101397 Pa
Voltage: 1.804 V
Hex: 99040368060FC5B0FFC9FFD503F20C19
RSSI: -89 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403471954C5C8FFF5FFF2040B0C0D
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101397 Pa
Voltage: 3.340 V
Hex: 99040368060FC5B0FFC2FFD803F90C19
RSSI: -89 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403531B39C5AC0008001004050BE9
RSSI: -52 dBm
Temperature: 27.57 C
Humidity: 41.50 %
Pressure: 94229 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFF7FFF304100C13
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 4.876 V
Hex: 990403531B39C5AC0009000E04060BE9
RSSI: -53 dBm
Humidity: 41.50 %
Pressure: 94229 Pa
Voltage: 59.659 V
Hex: 990403471954C5C8FFF7FFF5040F0C13
RSSI: -27 dBm
Humidity: 35.50 %
Pressure: 101397 Pa
Voltage: 4.876 V
Hex: 990403531B39C5AC000B001004060BE9
RSSI: -51 dBm
Humidity: 41.50 %
Pressure: 94229 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFF7FFF2040F0C19
RSSI: -31 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 6.412 V
Hex: 99040368060FC5B0FFC1FFDB03F80C19
RSSI: -90 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403531B38C5AD000D001004040BEF
RSSI: -52 dBm
Temperature: 27.56 C
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 61.195 V
Hex: 990403531B38C5AD000E001204040BE9
RSSI: -52 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFF5FFF504080C0D
RSSI: -31 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 99040368060FC5B0FFC1FFDF03F60C19
RSSI: -90 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403471954C5C9FFF6FFF8040C0C13
RSSI: -30 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 4.876 V
Hex: 990403531B37C5AD0009001204030BE3
RSSI: -48 dBm
Temperature: 27.55 C
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 58.123 V
Hex: 990403471954C5C9FFF3FFF5040B0C07
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 1.804 V
Hex: 99040368060FC5B1FFC2FFDD03F60C1F
RSSI: -91 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95509 Pa
Voltage: 7.948 V
Hex: 990403531B37C5AD000E001304070BE9
RSSI: -53 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFF6FFF3040D0C0D
RSSI: -29 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 99040368060FC5B0FFC0FFDB03F70C19
RSSI: -92 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403471954C5C9FFF8FFF404100C0D
RSSI: -27 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 990403531B36C5AD000A001204070BE9
RSSI: -47 dBm
Temperature: 27.54 C
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFF9FFF704100C0D
RSSI: -29 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 990403531B36C5AD0008001104060BE9
RSSI: -54 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 59.659 V
Hex: 990403471954C5C9FFFAFFF6040C0C0D
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 99040368060FC5B0FFBEFFDB03F90C19
RSSI: -88 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 6.412 V
Hex: 990403531B36C5AD000C0014040C0BEF
RSSI: -50 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 61.195 V
Hex: 990403471954C5CAFFF6FFF4040A0C13
RSSI: -31 dBm
Humidity: 35.50 %
Pressure: 101909 Pa
Voltage: 4.876 V
Hex: 990403471954C5C9FFF4FFF3040C0C13
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 4.876 V
Hex: 99040368060FC5B0FFC2FFDA03F70C1F
RSSI: -89 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 7.948 V
Hex: 990403531B35C5AE000F001004070BEF
RSSI: -51 dBm
Temperature: 27.53 C
Humidity: 41.50 %
Pressure: 94741 Pa
Voltage: 61.195 V
Hex: 990403471954C5C9FFF5FFF1040C0C0D
RSSI: -31 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 3.340 V
Hex: 990403531B34C5AD000E001004020BEF
RSSI: -54 dBm
Temperature: 27.52 C
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 61.195 V
Hex: 990403471954C5C9FFF7FFF2040C0C07
RSSI: -26 dBm
Humidity: 35.50 %
Pressure: 101653 Pa
Voltage: 1.804 V
Hex: 99040368060FC5B0FFBEFFDC03F90C1F
RSSI: -89 dBm
Temperature: 6.15 C
Humidity: 52.00 %
Pressure: 95253 Pa
Voltage: 7.948 V
Hex: 990403531B34C5AD000C001104030BEF
RSSI: -48 dBm
Humidity: 41.50 %
Pressure: 94485 Pa
Voltage: 61.195 V
Hex: 990403471954C5CAFFF9FFEF040C0C13
RSSI: -29 dBm
Humidity: 35.50 %
Pressure: 101909 Pa
Voltage: 4.876 V
