I follow the link below to flash and update the weather stations firmware on my ruuvitag.
I press âBâ button to turn it in raw mode, and now nothing.
My ruuvitag is detect by android app ânRF Connectâ but it is not possible to connect it.
If y understang is good, raw mode transform the ruuvitag in weather station beacon ? itât right ?
If you want to be able to use the raw mode, you need to be able to read the data that is sent, but to do that you need a specialised application because is comes as âManufacturer Specific Dataâ
If you run on linux with python 3.5 or better, you can try
pip3 install aioblescan
I will try with your scipt frawau.(accelerometer data is available ?)
My gaol is to send this value to domoticz (smart home software).
I have allready some python script whose convert value of beacon senson and send it to domoticz.
The aim of aioblescan is to log the sensor values in my home automation system (AutoBuddy) and it works. Since it is a library, admitedly with very limited capacity as of now, you should be able to use this in your own script⌠but as of now you need python 3.5 or better.
To use the library, all you have to do is define you own call back that does
import aioblescan as aiobs
def my_process(data):
ev=aiobs.HCI_Event()
xx=ev.decode(data)
xx=aiobs.RuuviWeather(ev)
if xx:
print("Weather info {}".format(xx))
Then in the main part do
event_loop = asyncio.get_event_loop()
#First create and configure a raw socket
mysocket = aiobs.create_bt_socket(mydev)
#create a connection with the raw socket
fac=event_loop.create_connection(aiobs.BLEScanRequester,sock=mysocket)
#Start it
conn,btctrl = event_loop.run_until_complete(fac)
#Attach your processing
btctrl.process=my_process
#Probe
btctrl.send_scan_request()
#Sit pretty
event_loop.run_forever()
