To sum up latest discussions etc from Slack, the latest proposal would be as follows:
offset = description
0 = Data format (8bit) whatever the next number will be (likely 5)
1-2 = Temperature (16bit signed) in 0.005 degrees (-163.84 to 163.83 range)
3-4 = Humidity (16bit unsigned) in 0.0025% (0-163.83% range, though realistically 0-100%)
5-6 = Pressure (16bit unsigned) as it is in format 3
7-8 = Acceleration-X (16bit signed) as it is in format 3
9-10 = Acceleration-Y (16bit signed) as it is in format 3
11-12 = Acceleration-Z (16bit signed) as it is in format 3
13-14 = Power info (11+5bit unsigned), first 11bits unsigned is the battery voltage above 1.6V, in millivolts (1.6V to 3.647V range). last 5 bits unsigned is the TX power above -40dBm, in 2dBm steps. (-40dBm to +20dBm range)
15 = Movement counter (8bit unsigned), incremented by motion detection interrupts from LIS2DH12
16-17 = Measurement sequence number (16bit unsigned), each time a measurement is taken, this is incremented by one, used for measurement de-duplication (depending on the transmit interval, multiple packets with the same measurements can be sent, and there may be measurements that never were sent)
18-23 = Tag ID, the 48bit MAC address (rather than the hw ID on the nRF chip to provide compatibility with current datasets that differentiate tags based on the MAC)
Most notable was replacing packet sequence number with measurement sequence number, as itās more relevant for measurement de-duplication.
FYI The following is a response I got back from bosh-sensortech.com in response to my question: from the data sheet AH is +/- 3% in the range of 20% - 80% . What is the accuracy above 80%?
From the factory:
According to our characterization, the absolute accuracy is also +/-3%RH from 80%RH ~ 90%RH range and within +/-6%RH from 90%RH ~ 100%RH.
The raw data from BME280 is 16-bit unsigned integer named as UH. After the formula based on factory trimmed values and final temperature (FT) reading, UH is converted to final humidity value FH. Every digit change in UH, will cause about 0.008%RH change in FH. This is where the 0.008%RH resolution parameter comes from.
So using a 16bit unsigned int makes sense in the Data format for humidity. Regarding the reported voltage, I think the measured shutdown voltage should be tested, as based on my prior measurements, the tag reports about 0.1V less voltage than the battery actually supplies, so 1.6V minimum in the format might actually be too high, if the tag can go down to 1.7V real.
@otso do I remember correctly that you have an adjustable lab power supply?
I think that kind of rarely/never changing info (firmware version and hardware version) would belong to the āscan responseā along with a friendly name and other things (to be implemented in the future).
Also, the data format id does not directly differentiate between URL and RAW modes, you can very well send formats 2 and 4 as manufacturer-specific data, or format 3 in an Eddystone URL if you use a short enough domain. This allows the actual data to be sent in many different formats, in different ways (encoded in an Eddystone URL, sent as manufacturer-specific data in a undirected BLE advertisement, or sent as a scan response, or even sent along a ātraditionalā directed communication)
Correct, for Base 64. Nobody says you have to use Base 64 Base 92 can fit 13 bytes of data per 18 characters, and you could as well come up with your own encoding
I think repeating the MAC address is redundant and a big waste in such an environment. Apple might fix their software one day to reveal the MAC address from the Bluetooth advertisement? The chip ID could be more useful. People using buggy software stacks can still use this field for identification. And then the chip ID could also be correlated between raw and URL modes.
There could be space for firmware version and other stuff if you encoded bits at non-byte boundaries. Eg. you can chip off 2-3 bits from format id, humidity and each acceleration field. I see how it seems difficult for beginners, so for each format version I would suggest publishing a reference decoder library in a couple of languages. This could be community contributed even.
Iām pretty sure Apple will not reveal foreign MAC addresses in the foreseeable future, as they were āintentionally hiddenā for āsecurity reasonsā. If this changes some day, then perhaps a new data format can be introduced that does not contain the MAC address. Also the data format 4 (url with partial id) does not contain the entire HW id, so a 100%-proof mapping cannot be done. Most existing implementations already differentiate the tags by MAC address as thatās the only thing available for differentiating format 3 tags, itās much more beneficial to ākeep the compatibilityā with MAC rather than partial ID, especially since the URL formats are not intended for logging purposes due to the reduced accuracy.
There has been discussion (mostly on Slack) about including the ārarely changing dataā such as tag revision, firmware version and hw id in the scan response rather than the broadcast/beacon packet, and that way you can then keep a record about tags, their IDās and MAC addresses.
Of course if you have specific needs that arenāt fulfilled with any of the āofficial data formatsā, you can always create your own.
If Apple doesnāt want people to see MAC addresses, I think they might be creative enough to do something bad against Ruuvi users who circumvent that. But thatās a very pessimistic scenario.
The main reason why I said the MAC would be redundant is the following: People who are using iOS canāt access MAC addresses now anyway, so they wonāt care what the new field will contain as they have nothing in the past to correlate this with. And people who are not on iOS they already have access to the MAC, so they wonāt get anything new from the newer data format. The only way this can be useful to someone is if you have a collecting software on non-iOS (with MACs) and you want to migrate that to iOS, which is quite improbable I think.
Adding non-measurement device info in the scan response sounds great. I didnāt know these types of beacons can emit multiple frame types.
Well, for example users could be using multiple devices to collect ruuvitag data to a more centralized place, for example using the official Android application to send the data to a gateway, and Iām pretty sure the iOS application will have the same feature when itās done.
And as far as I know, no existing implementations rely on the tag id (only on format 4 currently, and not in full there) for differentiating between tags when logging data, so even if itās of little use to have the MAC included in the format, itās more than nothing
maybe just a documentation issue: shouldnāt be the āinvalidā values for battery voltage = 2047 and tx power = 31, since 2048 / 32 canāt be represented by 11 / 5 bits?
