I would need to check if the doors of the trucks in my fleet are open or closed at any time.
In the 2 doors, when they are closed, I would like to place 2 RUUVI in each door.
When the doors open, the 2 RUUVI move away.
Can they dialogue and understand if they move away from a certain width?
Example, if between 2 RUUVI the distance is 10 centimeters, = doors closed, if greater = doors open.
I would also like to attack them at the door in an intelligent way, which, if it is detached, must signal it to me.
Do you say we can do it?
lauri
2
A hall effect sensor or a magnetometer and a magnet would work. But, unfortunately, RuuviTag has neither of these sensors onboard by default.
Check puck.js instead
