I am monitoring temps in different parts of my country plot (from the city 50 km away) and I just noticed that one of my tags suddenly switched from RAW mode to URL mode. I can see it because the temps are now transmitted with 1 degree precision and some other measurements available only in RAW mode have just disappeared.
The temp when it happened was around -5 Celsius (this very tag has survived -24 a week ago), battery voltage was around 2.881 volts (other tags show less).
I wonder if it ever happened to anyone else? Is it a bug or a feature?
I would guess this is caused by tag resetting itself for some reason.
Upcoming firmware release boots always in RAW mode and further down on roadmap weāll store the mode to flash.
This has happened to others, mostly in environments with heavy vibration
Thank you otso!
If it becomes regular occurence I guess I will need to upgrade firmware to the new oneā¦
There should be no vibration there at all unless some freak hare decided to play with the tag a little and then put it back where it was
PS Iām so glad Scrinās RuuviCollector collects data in all formats - even after the tag unexpectedly changed formats, Iām still getting whatever information available logged!
I actually had this happen to my tag located indoors in my Sauna, not moving or vibrating at all. By inspecting the measurements just at the time of the āresetā, it seems that the measured battery voltage was dropping rapidly right before and eventually the tag shut down, until the voltage was restored a bit later.
I believe this was caused by thermal expansion and some dust or so getting rolled between the battery clip and the battery, or some other environmental effect causing a temporary disruption in the voltage supply.
Iāve also noticed that the voltage is much more consistent if I gently wiggle the battery clip along the battery surface āscratchingā a few times back and forth after inserting the battery or removing the plastic clip, probably some dust or residue or something is left there otherwise.
When I went to check on my tag that had rebooted itself for no apparent reason, I noticed the gaping hole where the sticker had been. When I opened the case, the sticker was lying on the circuit board and looked intact - no evident mechanical damage like in Eternytās case. It even retained some āstickinessā so that I was able to stick it right back to where it had been. I have no idea whether the sticker incident had anything to do with the tag rebooting itself but I presume that any stats might be helpful to the manufacturer. The tag had been sitting outdoors for the last four weeks with temps between -28 and -1 Celsius, sometimes sun shining on it.
I believe this is first time we hear the breathing sticker has gone loose without birds knocking on it
If I would need to guess: not perfect sticker assembly (at our factory) + really cold environment + sun shining on the tag heating it quickly. Or a bird with a not so sharp beak
I went to check on the re-applied sticker to only find it undone and lying inside the box again. Took a closer look and decided to take a picture of āno evident mechanical damageā (after I stuck it back into place)
I wonder what makes Ruuvitags so attractive to birds?
Not a bird expert but Iām pretty sure itās the hole, looks like it could be a little hole like in trees with possible insects or other āfoodā inside
Sounds reasonable. Maybe attaching the sticker on the outside of the box will decrease the ābird appealā as there will be no perceivable hole to probe?
We are putting the finishing touches on the solution we built around use of RuuviTags (manufacturing environment). We have not seen this behavior in the few tags we have been testing with for our pilot, but I can see this being a valuable configuration as we begin to deploy(the fewer plant managers needing to monkey with a tag and press the āBā button, the better!) Any rough idea of when this behavior of defaulting to RAW might be on production units being shipped on new orders?
The current FW is in beta, and can be found at https://github.com/ruuvi/ruuvitag_fw/releases/tag/1.3.3-beta . @lauri can update you on the schedule assuming no bugs are found
